Pool filter and pump are of unknown age - plaster pool itself was installed in the early 60's.
What would you do???
Single speed main 0.5hp pump bearings are starting to let me know its time for a new motor.
Filter cartridges for the Sta-Rite system 3 are getting a little ratty. Might be able to make it one more season...maybe. We are planning on doing construction on the main house property...so the pool is likely going to be full of dirt & debris.
We have a letro legend pressure side cleaner that was recently replaced (scored an awesome craigslist deal)...
Here are my options:
1) Replace pump with Pentair 3hp variable speed that everyone loves
2) Replace pump with Pentair + new Cartridges?
Catridges look to be $300. I'd rather replace them with the retrofit kit, but that looks like it will be ~$450 and puts me 60-70% of the way there to a DE filter...
3) Replace Pump with Pentair and install a new DE filter?
Is the DE filter worth it?
I have no plans to ever install a SWG. I have a stenner pump + chlorine barrel that I will eventually use. The current setup is plumbed with 1.5" copper pipes. I have two returns, single drain, and skimmer. Current surface action is marginal - on windy days, forget it.
Pool stays relatively clear when the filter is clean and runs for 8hrs+ per day. Overall, pretty satisfied with current setup...but if the DE filter means less maintenance and clearer water, then I'd be interested.
See Attached photos of the setup...The heater has since been torn out and electrical cleaned up. It was a horror show. Nevermind about the photos...keeps telling me my quota has been exceeded, regardless of the photo size.
