I'm about to start construction of new inground pool. Should be done in about 3 months.
My research took me to what to fill the pool with once done (lol, yes, water, but what kind?).
Water in my city is hard. Found that hard water can create problems.
My initial plan was to get local fire to cone by, tap into hydrant, drain bunch out, then fill pool.
That would put bunch of hats water in.
Then I read I would have to increase ph, above 10, get calcium to solidify. vacuum, then reduce ph.
Is that only way? Can you share your wisdom on this? Can I live with hard waywf in pool? What are drawbacks? Should I get soft water? Called one place who wanted 500 bucks for 4000 gallons. I would need about 40,000 gallons. Advice greatly appreciated. Thanks.
