- Jul 22, 2023
- 267
- Plaster
- Pentair Intellichlor IC-60
Based on my current measurements, what is recommended to leave in the pool if gone for 8-9 days?
No, will get it installed around end of Sept.Is your SWCG running yet?
Unfortunately, not possible.Then you will need someone to come to the pool every day or at least every other day. Is that possible?
I've already passed the 30-day mark. The pool is in a screen enclosure. The skimmer rarely needs cleaning. I'm more thinking FC and pH maintenance.You have a dilemma. No one to clean skimmer baskets, add acid (with new plaster), brush, add chlorine.
I would check with your pool builder if you can hire someone.
PB was telling me to leave off for another month. I also didn't want to start something new and not understanding what attention it may require.You should have gotten the SWCG started.
All you can do is put pucks in a floating chlorinator and ho
Any recommendations on a floating chlorinator and tabs type?Add salt. Raise CYA if necessary. Start SWCG generating 3 ppm FC per day. Monitor for a week or so and adjust.
I leave for weeks and the SWCG just runs. I get home and usually my FC is a little high. If no one can come by to add some acid every 5-7 days, I float a puck.
Is what it is. Load up a floating chlorinator with 4 or 5 pucks and see what happens. Be sure to tie off the chlorinator so it does not rest over a step or right next to a wall.
I believe I read the salt must be added day(s) before and chlorine stopped days before that?Add salt. Raise CYA if necessary. Start SWCG generating 3 ppm FC per day. Monitor for a week or so and adjust.
