I was swimming yesterday and noticed a lot of pollen and surface Crud from the windy day we had. The surface Crud did not seem to be making it over to the skimmers inlets as fast as I thought it should. My pool install was a nightmare so Im figuring out things through real trial and error. So I went to pool station and there are the two dials for the valves that control the suction from the main drain for one dial and the skimmer for the other dial. They were set so the skimmers were doing very little, and evidently the main drain had most of the suction? How much should be suctioning back to the pool station through each valve. I was tempted to maybe have the skimmers at like 75% and then the main drain at 25%. And by percectage I mean I would kind of gauge where 75% compared to where the off position is. Some guidance on this would be very helpful.
Thank you!
Thank you!
