What to expect for N Texas Pool Maintenance in Winter
Hwmeador
Active member
May 8, 2022
34
Ft worth, TX
What does pool maintenance look like in N Texas (FT Worth) through the winter? It doesn’t look like anyone really closes the pool and just runs em year around.
Do I just keep up with normal maintenance and Chlorine? Will my chlorine consumption drop drastically due to the lower temps and non usage of the pool? Is there anything else I need or should be doing to my pool? Can I reduce the pump run time?
Looks like you weather is similar to ours in inland so. Calif. I do just like you said. Reduce run time and keep up with chlorine as usual. Consumption is dropping and will continue to drop, especially with cloudy weather. I never even cover mine. Water gets into the 40s, I still jump in for a quick lap. It never gets below freezing here for more than a few hours so that's not a concern. Watch the CSI, it will be a lot different with low water Temps.
Hw,
I treat my pool the same in the summer as I do the winter with the exception of chlorine. Since I have a SWCG, it quits making chlorine in the winter when the water temp is below 52 degrees, so I use Liquid Chlorine.
You are correct that chlorine consumption goes way down in the winter.
My pump run 24/7/365. I like to skim all the time and I like not having to worry about freeze control.
Reducing your pump run time won't save you much unless you are running your VS pump at very high speeds.
Reactions: KJB1
