I screwed up and now have 3 lbs of formerly dry CYA, now wet in a plastic bucket. I don’t have a use for it now. What can I do with it?
How did I end up with this problem? I was opening the pool after is sat for nearly a year. The chlorine and CYA were both low (like zero) and all I could find to add CYA was Dichlor so I used that until chlorine was very high but my CYA was still less than 30.
Mistake: I only waited one day between adding Dichlor and testing CYA.
It took a week to get dry CYA via mail order. When it arrived I hung 3 lbs in a cloth bag in the deep end. As soon as it went in the water I realized I should test once more, and sure enough CYA was already 50+. Three pounds would put it over 80 so I pulled the bag and dumped the wet CYA in an old plastic container with a lid.
Can I store it this way for future use? Seems risky to me, a bucket of CYA slush.
Can I let it dry out an return to its former dry state?
Dilute and disperse in an environmentally safe way?
Suggestions?
Suggestions?
