What size back wash hose do I need?
cowboycasey
4,309
Fletcher, OK
Schedule 40 is the type of pipe that can handle pressure and DWV is for drains like under your sink that have no pressure in them, in lowes they are on the same isle but at different ends of the isle.. :)
Reactions: Limey
Limey
111
Central Florida
I managed to find a coupler to make existing 1.5” pipe down to 1” so that I could put the new hose over it. Just attempted my first back wash and the hose split under pressure. I think it’s because the hose is closed flat and has been stored this way in a hot garage ?
cowboycasey
4,309
Fletcher, OK
well that sucks, the hoses do get stuck together.. if you start the flow easy and let it fill up and then turn it up it should not do that... This is a mango hose, it lasted me 5 years now... You can get a 1.5 or 2 inch.. :)
Limey
111
Central Florida
Would you know how I can get the flow to start of slowly so that the hose can open up properly? On my Hayward sand filter there is just an option for backwash and rinse and maybe drain I think. Does one option option reduce the flow pressure ? Thanks.
proavia
1,970
Chandler AZ
If you have a variable speed pump you would start off at a low rpm. You may have to temporarily set the prime cycle to a lower rpm also. Make sure the hose is laying flat, no kinks or sharp bends.
cowboycasey
4,309
Fletcher, OK
Sorry, I have a 3 way valve so I can slowly turn it... You have no way of doing that... I tell you that hose should take the flow with no issues, it is a trash hose and way thicker than a pool hose... :)
Limey
111
Central Florida
Thanks. No it’s not variable. I need to go buy a stronger hose I guess.
