What material is my pool?
Welcome to the forum.
Looks like fiberglass. Might have been applied over an old gunite pool. Is it the same through out the pool.
Reactions: JamesW
It's definitely field applied fiberglass.
You can tell from the fibers.
It might have been applied over gunite or maybe a fiberglass shell.
Ahh, of course. The fibers--it's so obvious now!
I needed to know what material my pool is so I can move onto the next step: addressing the high level of CYA. Currently, my CYA is at 140 ppm. I want to partial drain my pool to start treatment, but with any inkling that my pool was fiberglass I was hesitant based on what I read. Now that I know the pool is gunite with fiberglass, would you it's safe to proceed?
I doubt in San Jose you have shallow ground water regardless, unless you are right on the bay.
How are you testing your pool water chemistry?
Nope, I'm more inland! I took a sample in to get tested at the local Leslie's and that's the result they came back with. I have a Taylor K-2006 coming soon, so I can test more thoroughly on my own, as I'm not sure how accurate Leslie's is.
