Hi all, I'm back after a long hiatus. I used to have a 12K gallon in-ground pebble-tec pool that came with the house we bought in AZ. I used this forum to learn to maintain it. Well, long story short--we ended up filling in that pool because we didn't use it much and it consumed most of the space in our small yard and too much of our time and money. I don't miss the big pool, but now I think we might try a tiny pool, a.k.a. a hot tub (have never owned one before).
I'm looking at round cedar hot tubs with vinyl liners. I've identified two possible candidates that are pretty similar in price. I hope you all can give me your opinions. Here are the specs
Great Northern Hot Tubs
~10 weeks lead time from Minneapolis, MN
5’x4’ cedar hot tub w/liner
Standard foam cover (rolling cover is extra $)
3 hp pump
6kW heater
4 benches
5 jets
Canadian Hot Tubs
~14-16 weeks lead time from Kitchener, ON
Rolling cover included
1 hp pump
4 kW heater
“Surround” seating/4 benches
4 jets
The difference in price is about $1000 more for the Great Northern model once I add a couple of jets and a rolling cover. My biggest question is about the pump and the heater. The included pump and heater on the Great Northern one seem stronger, but I don't know if that's necessary or better since this is more of a hot tub than a "spa." The Great Northern heater is also stronger, which I know means it heats up faster, but I live in north Phoenix, AZ. The low temps in the summer are in the 80s and in the winter the coldest it usually gets is maybe 35 but it's often around 50 degrees F at night. Maybe we don't need the stronger heater? We might leave the heat off during June through Sept. and use it as a "pool."
My other question is about the base for the tub. I was going to have a paver patio installed for the tub, but then I got worried after reading some hot tub manufacturers strongly recommend 3-4 inch thick concrete as a base. Both the cedar tub manufacturers have told me pavers should be fine. Great Northern also recommended placing 2-inch thick high-density extruded foam (like the kind used for insulation--"Foamular") under the tub/on the pavers--not sure if that's just for insulation or for extra support or both.
Does anyone have any advice or opinions about this? Thanks again! I'll share some photos once we get going on the project
3 hp pump
6kW heater
4 benches
5 jets
Canadian Hot Tubs
1 hp pump
4 kW heater
4 jets
