I've noticed a black sticky substance. It's only in the grout lines on the corners of my pool and is slightly above the waterline (probably partially below the waterline at times depending on water level). It's only in the corners of my pool on the grout line between the tiles. I've ordered a small wire brush to clean it, but should I be concerned about it? Not sure what it could be.
