Hi everyone-
As I've mentioned, I'm in year 1 of pool ownership. It's been super awesome to just walk out of the back of the house and take a quick dip in the pool! Now I'm working to make sure it stays easy and simple. I was looking at my "pad" with pump and filter, and I am unable to identify all the parts. Can you help?
This is a picture of most everything from one side:
Same shot, a little bit higher:
And here is the view from the other side (there is a small fence with shrub in front of the setup so I can't get a picture perpendicular to the house):
Ok, here is the first picture again, this time annotated:
1: pool return
2: waterfall return
3: vacuum port
4: skimmer port
5: main drain port
6: automatic chlorinator???
7: ??? (I found this after I moved the hubcap you see at the bottom left of the picture)
8: ???
9: ??? (I'm guessing this is some sort of broken suction gauge to tell how much force the vacuum is sucking with? I have no idea)
I'm willing to get some gloves and gently dig some of this stuff out if necessary to get better pictures or more information.
Bonus question: why would I have two intermatic pool timers? (You can see on the third picture above) Currently I only use the one on the left, and it controls the pump. To date I haven't found an automatic pool cleaner, heater, saltwater chlorine generator, or anything else pool related that would benefit from a 2nd timer.
Thank you in advance!
1: pool return
2: waterfall return
3: vacuum port
4: skimmer port
5: main drain port
8: ???
