What is the difference between the Hayward W3AQ and GLX-CTL-RITE?
caliskier
359
Oklahoma City, OK
One other question does the Omnihub actually tell you on your phone how much chlorine is in your water? Or is it just used to turn equipment, lights, etc, off and on?
Sounds like the 940 will only tell you what your salt is in PPM, but will not tell you what your chlorine level is, so you would still need to go out and test.
ajw22
18,072
Northern NJ
Correct. And the salt level is a guess so you need to test to get an accurate reading of the real salt level.
caliskier
359
Oklahoma City, OK
OK, I know I don’t need automation, I want Automatic testing which does not really exist. I read some posts about the pHin, all that is is a great business model to get money from people that don’t know what they’re doing.
Rattus Suffocatus
1,027
Corona de Tucson, AZ
If you really want to get confused... take a peek at the Universal 40 SWCG I bought from Circupool. The "DSP" board is laid out with the LED's horizontally instead of vertically... but... I think it's fundamentally the same unit as the AquaRite. After reading the Hayward manuals at lunch today, some of the stuff I see on the diagnostics sure give me that feeling.. I think it even identifies the cell as a T-15. I will check when I get home.... Maybe the pinouts are different or something... but I understand the operation of my unit a lot better after reading Hayward's info.... fun stuff....
