What is my Polaris picking up in my pool?
RSay
9
Charlotte nc
Jandy Truclear / Ei
Likely calcium flake. Your CSI is pretty high. Take some and put a drop or two of muriatic acid on it. If it fizzes, it is calcium.
I would recommend you lower your TA. If you can get it down to 80-90, you will get close to 0 CSI.
If you follow this process, and cycle between 7.0 and 7.4 while you are doing it, it will a) go faster (CO2 outgases the fastest between 7.0 and 7.4 and 2) lower pH will lower the CSI and likely stop/slow the flaking while you are lowering TA.
MY FIRST EVER POST!!!!! I think my signature line is properly set up with all my pool "stats." LOL
I am having the same issue!!! My pool is brand new (completed 12/2023). I have not had any issues until about 3-4 weeks ago. Seemed to coincide when I started adding Leslie's No Phos and the Conditioner. Anyways, I am vacuuming 3-4 times a week to keep up.
My last test report from Cayman Pools (6/20) was:
TC: 1.9
pH: 8 (I did put MA in to bring down)
TA: 93
Calcium Hardness: 203
CyA: 59
My own test last night (6/23) was:
TC: 1
pH: 7.8
TA: 100
Calcium: Don't know. Don't have test for it but it's been steady per pool company tests between 203-215
CyA: Don't know. Don't have a test for it.
Thoughts? And I am going to post a separate issue about the chemical levels because I am beyond confused and frustrated. You may want to check that one out before you answer this one LOL.
As for the bubble thing above....you mention attaching to a pump but the picture looks like it's attached to your return. Explain please? I'm too scared to attach anything to my returns but I may be able to figure something for the sump.
Your signature does not indicate whether you have a sand or other type of filter.
That looks like sand. Likely from a broken lateral or MPV on a sand filter.
It could also be calcium, but less likely. Take a bit and put some muriatic acid on it. If it fizzes it is calcium. To know where it is coming from, we'll need more information.
Seems you don't have one of the recommended kits. I'd get one ordered now so we can sort this out. Link-->Test Kits Compared
As for the bubble thing, you don't need it!
Could it be precipitate from the addition of No Phos?
