What is he difference between Trichlorocyanuric Acid and Trichloro-s-triazinetrion
poolguy1975
In The Industry
Sep 15, 2020
1
Mesa, AZ
With the chlorine tablet shortage, I was wondering whaat the difference is between these two chemicals. They are both stabilized chlorine tablets.
HermanTX
1,378
Katy TX
I pulled this info off of the fact sheet.
Trichloro-s-triazinetrione is a dry solid containing the highest (90%) available chlorine content of any chlorine sanitizing pool treatment chemical except gaseous chlorine (100%).
This chemical is also known as trichloroisocyanuric acid or trichlor for short.
Trichloroisocyanuric acid is an EPA-registered pesticide sold for use as a sanitizer for pools and spas.
Trichlor is soluble in water, forming hypochlorous acid and hypochlorite ion or free available chlorine (FAC). Hypochlorous acid is more effective as a biocide than hypochlorite ion. The relative amounts of hypochlorous acid and hypochlorite will depend on pH.
Therefore, always maintain the pH between the recommended values of 7.2 and 7.8. The biocidal properties of trichlor are due principally to hypochlorous acid, which kills bacteria, algae, and other microorganisms. Because a residual level of FAC can be maintained with the use of trichlor, it is classified as a primary sanitizer. Trichlor is sold in tablet, stick and granular forms.
JoyfulNoise
Platinum Supporter
May 23, 2015
17,620
Pentair Intellichlor IC-40
Exact same thing. Just different ways of naming the same chemical. Chemistry has multiple ways you can name the same thing.
Reactions: poolguy1975
