Excellent info Brad!UV and/organics consumes chlorine. You have a covered pool the majority of the time. So that leaves organics. SWG are designed to keep up with a set FC level, when utilizing the FC/CYA chart. Per this thread you've set your SWG + pump run time = FC 3.2 ppm
With your climate in San Diego a FC loss of 3.2 this time of year would be acceptable. Since your post doesn't show testing everyday, it is difficult to really understand your FC losses. Because your pool is covered the majority of the time, you feel the FC should keep rising because the sun (UV) isn't burning off the chlorine. Which leave organics.
You really need to perform an OCLT. With your cover open all night, test your FC level after dark and before sunrise. (yes, set an alarm and test before the sun comes up). I believe I read in this thread you did an OCLT and had a loss of FC greater than 1 ppm. Which means you have organics.
Those were my thoughts. I have an autocover and I still keep my CYA in the recommended value range around 70 ppm. However, I open my cover most days between 12 pm to 6 pm. I am part of the #FCrunhot crew and keep FC around 8 - 10. Swim parties or not, FC has never dropped below minimum, that is why I have a SWG. Oh, btw, today mine is set for 24/7 33% which yields 3.0 ppm.
So I didn't fill in the every day numbers recently because at this point it is pretty much stable at 18fC daily since we aren't using the pool.
And you are saying if I am generating 3.2ppm per day and also losing/being-consumed 3.2ppm per day, then that is about normal for peak summer? So maybe I am not actually off then after all.
With the CYA of 35, running around 6fC should be fine if I can keep that stable with 3.2ppm generation per day. Ultimately I like what you are doing with 70 CYA and fC around 8-10. I will shoot for that in the coming weeks after I do the OCLT and drop the FC down .
Just to clarify when you say a FC loss of 3.2, do you mean throughout the daylight, or over 24 hours? I assume over 24hours
