Hello all,
I"m a bit frustrated and unsure how to proceed. I have an oval above-ground pool, but it's surrounded on all sides by a deck, and the deck is so close that we end up closing the pool like an inground one. No big deal, except it never works due to wind.
My house is basically surrounded by giant, open spaces, and we live in a somewhat windy area. No matter what I do to the cover (high density of water bags, a PVC rig I built), the wind gets under the deck, then under the cover and lifts it up. See the attached picture I took this morning.
This is my fourth year here, and the fourth year I've had this issue. Eventually, all it takes is one big gust and an edge comes up, exposing the water to dirt and debris. I try to stay on top of it, but it's impossible when you have two straight days of high winds as we've had here lately; I can go and tuck the edges back down, but they usually come out again before I can make it back inside.
I just looked at the water and there is a lot of dirt and stuff in there, which there typically is when we open in the spring.
We moved into this house in November, when we did the previous owner winterzied the pool but didn't cover it. In the spring, it took us awhile to get the water where it needed to be, but I'm not sure if that was because it was uncovered, or because it was the first time we owned a pool and didn't know what we were doing.
The liner is already shot as I bleached it too much when doing a SLAM. In fact, the whole pool is 15+ years old and has seen better days.
At this point, I feel like covering it (at least like we are) is a net negative - it's a lot of work, the water bags are getting pricy (we have about 1/2 break each year) and ultimately, I'm not sure what good it does.
