Not at this point, but I could a few days ago. There were leaves from the storm but nothing else.Can you see to the bottom maybe something else in there
HDX - Home Depot's house brand. It's good stuff.What brand of bleach/chlorine are you adding?
I'm central, so there's plenty of development close-ish but not close enough to be affecting my pool. And this has happened 3 times over almost 5 years, so I can't pin it on a recent change.Curious, what part of Austin are you in? That place has grown like crazy. Any new developments or local spraying that may explain something getting in your water? Do you have a neighbor nearby with a pool who is experiencing the same issue?
I've joked before that I could make a fortune bottling up whatever is eating my CYA. If you had high CYA, it would be a lot easier to use that stuff than to have to drain.Certainly is odd.A handful of us have thrown just about everything we could think of at you, and the common denominator seems to be low chlorine combined with local weather. I'm out in the country surrounded by corn fields and stuff. I get strong winds and junk in my pool all the time, but I've not had your scenario happen - yet. Keep that stuff up there.
"Drew's instant CYA remover."I've joked before that I could make a fortune bottling up whatever is eating my CYA. If you had high CYA, it would be a lot easier to use that stuff than to have to drain.
I've added 3 gallons over a couple days. Whatever is in the water is immediately canceling out the chlorine. I can't get it to register FC at all. As I said above, I suspected ammonia, but my ammonia strips don't register either.How much are you adding?
How long are you waiting to test?
Go to 20 ppm and then test within 30 minutes.
This has happened 3 times over the 5 years I've had the pool, so I do know how to fix it. It takes a crazy amount of chlorine (like 6 gallons) and eventually clears up. I'm really looking for the root cause, and that's why I posted it in the Deep End section. It seems to follow the description I've read of ammonia, but my ammonia test strips don't register anything. And if it is ammonia, how does it keep happening - that's what I'm trying to figure out.Add enough to get to 20 ppm and test FC and CC within 10 minutes.
Make sure that the circulation is good.
Possibly? We have a lot of trees, but it doesn't seem like that should be enough. Not getting any groundwater or runoff in the pool as far as I can tell. Our house is pretty new and we did a lot of work with the drainage. It's a head scratcher.Maybe bacteria in the local environment?
I heard multiple times that if you had CYA and it goes to 0 you probably have a leak.I've joked before that I could make a fortune bottling up whatever is eating my CYA. If you had high CYA, it would be a lot easier to use that stuff than to have to drain.![]()
The bleach I started with is only about a month old. I bought 4 more boxes today and have had the same experience. I must have ammonia in the water, I just don't know how it got there.You have an SWG, so you don't normally use bleach, right? Is it possible that the bottle of bleach you poured in had been stored for so long that it had lost its potency? Wouldn't explain the CYA, but maybe the FC.
As in water leaking out or in? Leaking out doesn't seem like it would affect CYA at all. Leaking in might if it brought in bacteria, but I can't imagine any leak being enough to affect your chemistry by much.I heard multiple times that if you had CYA and it goes to 0 you probably have a leak.
