Oh goodness, thank you! I have that app but was confused which one was associated with this site. After looking at the app I do have a question. I believe I have read on here that CH should be at a minimum of 120. (I have read so much info that I may have it jumbled up in my brain on where I've read it, though.) On the app, it suggests a range of 350-550. Which target should I be shooting for? If it helps, I just refilled the tub to start over and the PH is 7.6, Alk is 50 and CH is 60.We do not use or support poolcalculator.com
TFP has the PoolMath app. I suggest you download that and then we can assist you.
A hot tubWhat type of pool are we discussing?
See...
What Are My Ideal Pool Levels?
Use our tool to find ideal chemical levels for any swimming pool. Check TFP recommended levels on pH, free chlorine, cyanuric acid, and more.www.troublefreepool.com
