- Feb 6, 2015
- 8,055
- Plaster
- CircuPool RJ-45 Plus
When doing the CH and TA tests - are you continuing to add drops until the last drop doesn't change the color any further (and subtracting the last drop that didn't change the color) or are you ending the test at the first change of color (blue for CH / red for TA)?
Where exactly in Phoenix are you?
Are you on city water, well, or something else?
Most water anywhere in the Valley of the Sun is 200+ for CH and 100+ for TA
If you don't have a box on the wall that allows programming to control your pump - in your case a Pentair branded box for your Pentair pump - you don't have automation.
Your pump alone will not provide that and a simple timer box on the wall isn't automation either.
