Two down today:
1. Affixed the water level ruler. I decided to use a stainless steel screw into the grout (with a plastic anchor). I had originally intended on using epoxy, but then realized I may need to replace it if it fades, or move it out of the way for tile cleaning or just get rid of it if this idea does not pan out. One screw and done.
From phone:
I used a contractor's level to make sure the bottom of the ruler is even with the bottom of the skimmer opening. Today my water level is 3-3/8" above "ground zero."
I found a ruler that is white with transparent letters. So the white may disintegrate at some point, but the letters won't fade because they are just holes in the white.
From pool cam, and I can see it at night, too, with the cam's night-vision:
From pool cam, not too obnoxious from across the pool:
2. Got tired of fishing my skimmer basket handle out from the bottom of my huge green waste can. The handle pops off if I bang the basket just so when trying to dislodge leaves and crud. Only took me eight years to figure this out. Drill small hole, insert zip tie. Doh! Also figured out why it hasn't rusted all these years. It's brass! Duh!
OK, time for a swim and a beer!
