My pool is under construction and *fingers crossed* looks like it should be done in less than a month - My Pool Construction Thread
It's a 24K gallon salt water pool that also has an inline chlorinator, heat pump with chiller, variable speed pump, and three waterfalls. I've tested my tap water using the TF100 kit, and I also bought the stirrer and Taylor salt kit, so I think I have all the testing equipment I need.
I was hoping to get the group's feedback on chemicals to buy in advance of the pool being completed. I tested my tap water and got the following results:
pH 7.8
Calcium: 75 ppm (ideal is 350 to 450)
Alkalinity: 190 ppm (ideal is 60-120)
Based on the above, here's my thinking, and please tell me where I'm off base:
* Buy dichlor tablets and use my inline chlorinator for the first month. The tablets are convenient and have the benefit of adding some CYA to the water, which I'll need anyways. I'll transition to the salt system after the first month.
* Based on the internet tables I have found, I'll need 640 pounds of salt for my 24K gallon pool. I won't add this until after the first month while the plaster cures. I was thinking of buying less than that at first, maybe 500 pounds, and then test the salt level to make sure I don't overbuy salt.
* To lower the TA, I'll need muriatic acid. Per Pool Math, 6 gallons of 14.5% acid will lower the TA by 63 and the pH by 3.8. I understand that I should add a little acid at a time to slowly bring the TA down and then raise the pH by aeration. I was hoping my 3 waterfalls would be enough to raise the pH. Or should I go ahead and buy borax to help raise the pH?
* To increase calcium hardness, per Pool Math, buy 65 lbs of calcium chloride to raise the level by 293, making a total of around 360.
* To raise the CYA, buy dry CYA. Pool Math says 10 lbs will raise CYA by 50 and pH by 0.9. I was going to buy 10 lbs and then raise the CYA slowly each week until I get to the recommended 70-80 ppm after a month, when I start the SWCG.
pH 7.8
