- Oct 25, 2015
- 5,833
- Plaster
- CircuPool RJ-60 Plus
Sometimes we do rely on pool stores for metals since they are usually OK on this test only.
Good idea to get your kit early but it doesn't test for metals. Check the EPA test results for your municipal water supply.
Chris
Item Tested | Well | City |
Free chlorine | 0.03 ppm | not a part of the city's report |
Total Chlorine | 0.03 ppm | 1.67 ppm |
Combined Chlorine | 0 ppm | not a part of the city's report |
PH | 6.3 | 8.03 |
Hardness | 2 ppm | 23.8 ppm |
Alkalinity | 15 ppm | 23.6 ppm |
Cyanauric Acid | 2 ppm | not a part of the city's report |
Copper | 0 ppm | not detected |
Iron | 0 ppm | not detected |
Phosphates | 108 ppb | not a part of the city's report |
Salt | 0 | 0 |
You're correct, it was a pool store test.Luma,
Your city water actually looks pretty good. Where did the well test come from? Results look suspect. CYA is not naturally occurring and pH is very unusual/corrosive. Looks like typical pool store test results.
Thanks, Dave. We were trying to figure out what was best long-term. If a whole house water softening system would cost more than just switching to city (long term cost including filter material and wear) then we'd rather have city water.I skimmed the replies but didn't see this.............If you want to stay with a well, install a whole house water softener with enough capacity to use your house water for refilling the pool.
Truck in water for starters but then use the softened water and you are good to go.
Guessing a bit but I think $1500 - 2000 or thereabouts at most. Cheap supplies, too.If a whole house water softening system would cost more
