I finally got my leak fixed. The sand filter has been practically rebuilt. Last night I decided to clean out the pump basket. So i opened it up, took out the grime, and put everything back. When I turned it on it took a bit to prime and then everything was running smoothly as normal. Today when I turned the pump on, it sputtered out some bubbles and then was fine. I double checked to make sure I had completely screwed in basket lid. I had. I went back out to check on it and some water was leaking from the top of the filter by the multiport. I turned the pump off.
Any ideas as to what I have done to cause this?
