- Apr 6, 2019
- 107
- Plaster
- Hayward Aqua Rite (T-15)
UPDATE: Apparently my neighbor has a small citrus tree that is likely the source of the smell. It is a sickly sweet smell when it is breezy, and I hadn't noticed until I looked over the block wall. I also added a 15 second video of pump at 1328rpm (apx 5psi) so you can hear the sound as well.
Bad Pump Sound Video
Howdy all..
Noticed this today as I was working in the backyard.
*Weird "hollow" sound...
*Faint odor.... Goes away when I turn off pump.
Checked pump basket and skimmer, both free from debris.
Pressure usually 20-21psi @ 3450rpm. Usually run 23hrs @ 1328rpm (4psi) and 1hr @ 3450rpm to clear spa, etc.
Replaced with OEM filters on 2/23/25. Worked fine then with no problems.
Today 26psi @ 3450rpm. Obstruction someplace maybe?
Any ideas before I check cartridges and start running a pig through pad lines? Or should I just call someone based on the faint odor which seems to be coming from pump?
The odor makes me think it is a pump problem, but was new in 2018.
Thanks for your guidance!
Howdy all..
