My heater is piped only to my spa and not my pool. Before today in order to use my spa, I would hit the spa jet button on easy touch and the heater would kick on automatically to the temp I had set on the heater.. The heater would turn off when the spa jets were turned off. I didn't have communication between heater and easy jet. The screen on the heater would say Flo..
Today, I had someone try to connect the communication between heater and easy touch so that all was controlled threw easy touch. (he was then going to repipe so the heater would heat the pool also) HOWEVER..
After hooking up the communication cable and going threw the heater steps he couldn't get it to work.
Now after disconnect communications cable, the spa heater now needs to be turned on manually, it no longer works in Flo mode. If I turn the temp on the it comes on even with no water going to it. It then turns off with HP flashing and only the fan stays on.
Is there a way to reset the heater or get I back to the Flo mode?
Model: W6350TI-E
Model: W6350TI-E
