Hey, long time lurker but don't post much here at TFP.
I have a 15,000 gallon pool that I just converted to salt in our new home. I have a pentair DE filter, 3 HP pentair intelliflo pump that is about 7 years old, and just installed an IC40 salt cell with power center. My PB put in the check valve needed to protect the heater. Everything is working great with the cell and the water is clean but the spa returns are weaker now than they were before and the jets are weaker. I just have one pump without a separate jet pump. I've attached some photos of the setup for reference. Ignore the janky rubber coupling on the pump suction side. Someone got lazy I guess in the past.
Any help? I want stronger jets are stronger spillover in pool mode. The spa spillover is only like 4 inches above the pool water level. I can add that photo if needed.
Oh, and the PSI on the filter is only like 10 when running at 2250 RPM and 16-17 when running at 2750 RPM. I think my equipment is like 20 ft away from the spa side of the pool.
