Waterway PD-140 Overcurrent Error Code
theninjachachi
Active member
Jul 28, 2021
37
Arizona
Hi! Earlier this week I noticed my pump wasn’t running. (I have a a Waterway PD-140). I went over to check it out and it was showing an error with a red light saying “Overcurrent (HW) Error Code <E0>”. I tried resetting and restarting it and when I try to turn the pump on nothing really happens and it keeps giving me that error. I contacted one local pool repair company and all they said they could do is replace the pump.
Does anyone have any other opinions?
Your manual is at - https://waterwayplastics.com/manuals/810-4120-EFS-0819_PD-140Manual_lowres.pdf
2. Clogged impeller. Remedy:
a. Turn off electrical power to the pump.
b. Remove the bolts holding the volute to the seal plate.
c. Slide the motor and seal plate away from the volute.
d. Remove the diffuser.
e. Clean debris from impeller. If debris cannot be removed,
complete the following steps:
(1) Remove left hand threaded bolt and gasket.
(2) Remove, clean and reinstall impeller.
(3) Reinstall left hand threaded bolt and gasket.
f. Reinstall the diffuser and diffuser O-ring.
g. Reinstall motor and seal plate into volute.
h. Tighten bolts securely.
How old is your pump?
Have you tried contacting Waterway - 2200 East Sturgis Road, Oxnard CA 93030 • Phone 805.981.0262 • Fax 805.981.9403
