Recently been doing some equipment upgrades, and went with the 525 sq ft Crystal Water cartridge filter from Waterway (thanks for the rec Jimrahbe!) via Polytec.
Really well made, solid filter. My one gripe is the change they made to remove the side handle holds on the top that are still shown in product pics online. Pretty clear that the molds were changed since there's parting lines where the handles used to be (see pic), not sure on the reasoning for removing them but honestly I was looking forward to the easy with those there.
Anyway, I wanted to check with anyone else here that has this model filter if there's been any problems with air leaks from the manual relief valve on top? At low pump speeds it seems to let air bubble in slowly, and at higher speeds it actually drips from the sides. I've already tried taking it apart to check o-rings, seems like it came from the factory with the quickest slap of silicone and shoved in because one o-ring hadn't been touched by any silicone.
Even after getting a good silicone coat and putting everything back together nice and tight it's still leaking. Has anyone else run into this with this specific filter?
