Hi everyone,
We bought our first house with a pool recently and we had an algae problem shortly after a swim. We were able to fix it after going to Leslie Pools and spending a few $100s on products to correct and regular maintenance. Just when we think we are doing OK (regular weekly testing, adding shock once a week, skim/brush, etc.), we got our water tested today and the results are attached with high chlorine amongst other issues. I'm really hesitant on buying/spending more stuff until we really know how to fix/maintain regularly.
We test the water using the aqua check strips. However, ever time I tested it, it said the chlorine levels were low so I added more pucks to see if that will raise the levels on the test trips. We took the water sample today (see attached) and I am frustrated but not surprised that the chlorine levels are high.
My questions are mainly going to be around how to get this maintenance under control -
1) Wednesday is normally when we will shock the pool - since Chlorine levels are high per Leslie's pool - do we skip shock for a week? We also pulled out the chlorine floaty for the time being.
2) I'm frustrated and think maybe the test strips are not working? Chlorine seems to always be low or non-existent when there is clearly chlorine in the pool. Is there a better/more accurate test kit I should order?
3) Based on the Leslie report - we now may need to fix other problems - calcium hardness, cya, and alkalinity. How should we best proceed?
Since we've moved in, there are TONS of information on the internet.. and I'm hoping to learn more through TFP.
Thank you!
Stressed and Frustrated newbiepo0lowner from Sacramento, CA
Thank you!
