Water Test - Results
TheMax
18
Ontario
Hi Guys,
Free Chlorine 3.79 ppm
Total Chlorine 4.1 ppm
Combined Chlorine 0.31 ppm
pH 7.7
Hardness 116
Alkalinity 83 ( With colorQ my Alk was 70 )
Cyanuric Acid 49
Should I lower pH or is this decent results ?
Acrylic Hot Tub with Ozone
This was tested with SpinDisk .... my TF100 Kit is en route! :)
Hey TheMax and Welcome !! Fold the paper over a few times and use it as a coaster under the tasty beverage you should be enjoying while you wait for your kit to arrive. The pool store tests are designed to sell you chemicals that you don’t need. They’ll push your numbers up, then need to bring them down....... then.... ooooops it went to far, Here, buy this stuff to lower it all. With the much smaller capacity of a hot tub they can make it swing that much easier, and then sell you the fix.
Anywho, if those above numbers are close enough to actual, You need more FC. Bookmark theFC/CYA Levels so you can keep it handy. Use PoolMath to know what and how much to add once the kit arrives.
