- Nov 29, 2015
- 640
- Plaster
- Jandy Aquapure 1400
I tested my pool 2 days ago and the chlorine was 3 parts per million in the pH was perfect. That was from the pool the water temperature was 60 degrees. Tonight I tested the spa which runs with shared pool water the spa was 100 degrees the chlorine was it 9 + parts per million and the pH was off-the-charts high. No changes to the salt water generator or anything else recently is it common for test results to be so different based on water temperature?
