But it's almost 100 out there and the pool ducky says the water is almost 90.
My computer is saying different, the worst it says, cell is doing nothing; check cell, check salt, 35 volts at 0 amps, even though, the computer says it's superchlorinating and and shows 99p.
Chemistry and salt are fair, pool turned green yesterday and after adding chlorine and cleaning cell, looks better, some green spots on bottom.
I tested the water directly from the return hole, so I assume that tests the water returning from the filter, rather the whole pool water.
Any ideas? I suspect computer is broke again.
Thank you for any help.
