- Apr 29, 2018
- 328
- Plaster
- CircuPool RJ-60
So a little background. I have left the pool open (but now covered with the mesh safety cover because of all the hardwood trees) this winter here in the Atlanta area. In early fall I installed a Stenner Acid pump. I was tired of the weekly 1/2 gallon of acid pours. We swam until late October and the numbers stayed in the perfect range. They were incredibly rock solid. I have been a bit lax in water testing but the other day I ran the numbers and noticed that my PH was down to 7.0 - 7.2. I am assuming that because the SWG wouldn’t and couldn’t produce chlorine now that the water temp is so low and I have taken the swg out of the system that my Normal PH creeping up cycle is now perhaps less. The FC is around 10 which really hasn’t moved and now TA is 50. I dialed back the acid injection time to 1/2 of the daily amount and will go test this weekend again.
One other variable is that I was running the pump 8-10 hours a day during the swim season but now only running it 4 hours per day.
Depending on the responses from the experts about temperature effect and pump time, it does seem that the major contributing factor in my PH rise is directly tied to the operation of the SWG. (No water features at all)
Thanks.
Thanks.
