My CYA is 80. My intention is to keep my FC at about 10 and set my SWCG to produce around 4 FC to replenish what's lost. I plan to use the pool math app to see what % output I need to produce that (assume its zero, set a target of 4 and see what is needed for near 24hr output). I'll monitor and adjust as needed if my FC loss is significantly less than 4FC a day. Seem reasonable?Have we gone over how to *keep* it that way ? The FC/CYA Levels. Never approach minimum. Please allow me to quote Chris Tucker from Friday the 1st:
So your pool will consume FC everyday. You’ll get to learn about how much. Plan on losing it the next day and dose to stay in target with that loss. There is tons of leeway above minimum, all the way to SLAM, as a matter of fact. There is no leeway, and nothing but a bullet train to pea soup if you go below minimum.
Boom. Stupid clear pool forever.Seem reasonable?
+1. Once you know your daily trends you can lower the target from 10 as close as you wish. In the meantime the 3 extra FC will be your safety net when it’s a busy week or whatever life throws at you.With a CYA of 80 I keep my SWG FC at 7 at all times.. it works perfect and no issue for years now
Again. That’s personal preference and totally up to you once you get a firm grip.then I'll probably dial that FC 10 down just a little.
That’s what I do. I try to put people in a better mood so they are more open to attack the problem with a clean head.@Newdude, that made me chuckle!
