So, fairly suddenly, my water is not crystal clear. I wouldn't go so far as to say hazy, but it's dull. I can very clearly see the bottom. My wife thinks it has a green tinge, but I think it's because of the blue liner. I'm not sure if I should be concerned.
I don't have my log book with me, so I can't give exact number. These are the approx levels
FC is on the high side, 9ppm
CC is zero, or at least, less than .5
PH is 7.8
TA is up close to 100
CH I don't normally test, as it's a vinyl pool. Should I?
CYA is 70-80
My salt is low, about 2800ppm.
Some other possible useful information
My filters were cleaned about 5 weeks ago. The pressure gauge shows very low pressure.
It recently rained REALLY hard. The water looked great before the rain. The pool level was up close to the top of the skimmer intake. I drained some yesterday. It's now a bit above the middle of the intake port. Maybe it hasn't been filtering properly since the rain?
The bottom return pressure seems very weak, but I've never noticed what it was in the past. Should it be strong? I have strong flow at the jets on the wall, and on the waterfall when I turn it on. Even if I shut off all the other returns, the bottom return is very weak, but I have no reference as to how strong the flow should be.
Any ideas? Thanks.
PH is 7.8
CYA is 70-80
Any ideas? Thanks.
