Our spa/pool was recently remodeled. Full pressure test done before it started. Two of the spa jets were leaky and fixed.
The pool equipment and pool itself sits lower than the Spa, so gravity tends to flow water back towards equipment.
When the pump is running the water flows up thru fountain plumbing and spills over from spa into pool.
When the pump isn't running the water level typically holds high in the spa near the same place when the pump was turned off.
However, during cooler weather (50s) the level seems to be dropping a few inches per day when pump is off. I've changed all the check valves but it's still happening. I'm thinking that in cooler weather some seal is contracting slightly. Could it be inside a diverter valve? ideas?
