Hi All
Just went through the forum and found something very similar to my issue. However, there wasn't really a definitive answer/solution. The post is about 4 years old so I thought to post my question in a new thread. Originally by "thenateo" April 27, 2020 titled "Pump water level slowly dropping".
I have the same issue. I have used my VS pump for years without issue. Regardless of speed, the pump basket has operated full of water. No air bubbles whatsoever. Last season, I noticed a an air bubble or two of decent size but not concerning. Regardless of speed, the bubbles would not clear. This season, the amount of air at the top of the pump basket is significant. At prime (3000 rpm) it is a swirl of little bubbles. At my typical operating speeds of 1900rpm or 2400rpm there is a noticeable air space but again, not too concerning.
This season though, when the pump runs at 1000 rpm (this lower speed is used over night to prevent the heater from operating but continues to move water) the pump basket water level drops significantly to below the intake. This occurs within 10-15 minutes of the speed dropping to 1000rpm. Never done this before. Always maintained water level. I can not detect any sound of air sucking in (nor blowing out) and everything at the pad is dry. The pump seems to operate and moves water and you can clearly see water flowing out of the intake and falling into the basket. However, this is very concerning that the water level is so low. I can hear water flowing through the heater and filter as if pouring from a jug. As such, there is obvious air going through the system. If the pump is turned off during higher speeds, there is no loss in water level in the pump basket. An air bubble about the size of my palm remains and holds at the top of basket.
To recap: Never had air in pump basket for years. Last year a bit of air is present. This year, a bit of air is always swirling in the basket. When pump is off, a palm sized bubble holds in the basket. When the pump runs at low speed, the water in the basket drops to below the intake quite quickly.
As per picture, the suction side is skimmer and deep end drain coming into one intake at the pump.
Checked these two connection O rings/gaskets all appear good (no nicks, flat spots, dry spots, etc.). Same for the connection at the pump and basket lid.
I cleaned connection surfaces and lubed seals. Clamped everything down.
Picture shows pump off and palm sized air bubble that stays. Water level in basket does not change when pump is off. Only when running at low speed.
Any input, comment, suggestions is greatly appreciated.
