When operating my pool in normal mode (suction from skimmers and return to pool) my 2HP Pentair pump has maybe 3 or 4 bubbles that linger at the top. If I move the 2-way valve to suction from the spa bottom drain and leave the return to the pool, more air bubbles are introduced into the pump which makes me think I might have a problem with that 2-way valve lettting air in. If I move the 2-way valves to the spa for both suction and return the water level in the main pump drops fairly drastically like there isn’t enough water to keep up. What would cause this or is that normal?
