Water leaking from pool slide water on/off turn control near ( underneath slide ). Small crack in the open / close manual dial to turn on.water flow
DrDaveInTexas
1
Dallas, Texas
I have an in ground pool. There’s a separate pipe from pool pump to the slides/ladder. There’s an on/off manual turn on/off connector that lets water flow down the slide or not. There’s a small crack in the pipe and water is trickling out .
Is there a sealant solution to fix the the pipe as well as and seals on the on off connector ( 90 turn or not not to control on/off )
Welcome to TFP.
Post pics of the pipe on your slide and the cracked areas.
You probably need to do some PVC repair and cut out the cracked pipe and valve and glue new pieces in.
PlastAid may be able to seal a crack depending on the extent of the damaged area. Not sure what the issue is with the valve.
