I have an in ground pool. There’s a separate pipe from pool pump to the slides/ladder. There’s an on/off manual turn on/off connector that lets water flow down the slide or not. There’s a small crack in the pipe and water is trickling out .
Is there a sealant solution to fix the the pipe as well as and seals on the on off connector ( 90 turn or not not to control on/off )
