I have an interesting problem.
Every time I top off the pool using a hose, water starts to leak from what I think is the fill valve where all the pool equipment is. It only leaks when I fill via hose and stays dry the rest of the time.
I will add that I've filled up with the hose twice in a month, where before I would have to do it twice a year, so something might be up with the automatic filler. However, even if the automatic filler isn't working correctly, why would the valve leak when using a hose to put water in the pool? Any ideas?
