- Jun 7, 2024
- 429
- Vinyl
- Intex Krystal Clear
Ok, the moment we have been waiting for:Do it with 5mL sample for this test for now, each drop is 1FC.
When we get your pool down to normal levels, then use the 10mL sample from there.
Try it with 5mL sample.
Post a full set of results, FC CC pH, TA CH CYA and Salt
Ok. Chlorinator has been turned off and I'll leave the pool cover open until we go to bed tonightNothing to do for the moment. Leave the pool outdoor in the sunlight to allow FC to come down.
Stop using the CLBR test. Just use the drop test.
Test again in the AM?Nothing to do for the moment. Leave the pool outdoor in the sunlight to allow FC to come down.
I can't believe I went from 0 chlorine to 55 ppm. 4 lbs of shock and 4 gallons of liquid chlorine over the course of a week. Plus my chlorinator running normally (though 24-7). I'll get my pump back on its normal schedule.Its going to take a week or more to come down. Maybe 3 in Minnesota because its still early in the season for you. Save your reagents and test every couple of days.
No need. Here is your answer:Do some more searching for threads about both
4 pounds of cal-hypo will add 15-20 ppm FC, depending on strength.I can't believe I went from 0 chlorine to 55 ppm. 4 lbs of shock and 4 gallons of liquid chlorine over the course of a week. Plus my chlorinator running normally (though 24-7). I'll get my pump back on its normal schedule.
Good to know. ChatGPT says it will be safe my next Monday/Tues given all the variables. Not great swimming weather in the 10 day forecast anyway.4 pounds of cal-hypo will add 15-20 ppm FC, depending on strength.
4 gallons of 10% will add 22 ppm FC.
Not sure which T-cell you have, but even the T-cell 3 can produce 9 ppm FC per day in an 18,000 gallon pool.
So 55 ppm is well within the realm of possibility.
Swimming is safe between min FC and SLAM for your CYA level. (2 - 16 FC @40 CYA )ChatGPT says it will be safe
Please don’t ever trust ChatGPT with pool advice. It gets all its data from the Internet.Good to know. ChatGPT says it will be safe my next Monday/Tues given all the variables. Not great swimming weather in the 10 day forecast anyway.
But wait...we're getting all our data from the Internet (here) too!Please don’t ever trust ChatGPT with pool advice. It gets all its data from the Internet.
I just asked it to estimate when the pool would be back to ~10 ppm. Gave it my test results and the 10 day forecast. I'll be interested to see how it all pans out.Please don’t ever trust ChatGPT with pool advice. It gets all its data from the Internet.
