Water is still cloudy after multiple treatments
*assuming you get right on a kit being delivered. If its delayed for any reason, I'd use test strips to prove there was likely chlorine in the pool. The # isnt that important (yet) as said above and i'd try to stay on the darker side of the test strip.
Some folks think about it for a couple weeks or the kit has to clear customs and adding 5ppm a day may stack in a bad way.
Hes in Minnesota so I suspect he will have his kit in a week or less 👍🏻
Retest your pH now and post the result here.
If you added all the pH down that the pool store recommended, chances are the pH is way too low. If so, that needs to be addressed ASAP.
Reactions: Mdragger88
No, you’re simply adding 5ppm worth to the pool to account for daily losses while you wait. Not trying to maintain a specific fc level.
Thats a dab under a gallon- it doesn’t have to be exact, a gallon a day of 10% strength will do!
Put that robot to work !
Thank you! Gallon added and robot putting that work in.
