Hello all!
I'm new and need some help!
I have a hot tub that gives me a slight shock when I touch the water....I also have a heater that doesn't stop heating...put the water temp past 115 degrees.
Are both related or coincidence?
The green ground wires for the heater and motor have corrosion on them..could that be the problem?
The motor is hooked up into a GFI and the GFI isn't tripping...I replaced the GFI last year and things were running fine until I started the tub up yesterday.
By the way..tub is 1980's old school Hayward motor.
Thanks!
Thanks!
