Water Flow with probably poor plumbing design
Jun 2, 2017
60
Hurricane, WV
So I have a Barrier Reef 40 Coral Seas in ground pool. See attached. Skimmer on deep end along with 2 deep drains about a foot of the bottom. Only 3 inputs
I have drawn the direction that I have diverted flow but it still leaves a lot to be desired esp flow in the shallow end.
Any ideas? Are their resources that help with this flow direction problem.
Granted I thing I might have put two skimmers in to start with but we had a “professional” install (but pools aren’t as common here in WV)
Which way does your prevailing winds blow?
You have just one skimmer?
Not much you can do to improve circulation. It was set by the decisions on skimmer and return placement.
