Water flow only to pool slide but not the jets
DrewCT
5
CT
I opened my pool for the first time this spring. My pool slide gets water flow but none of the 4 jets are getting water flow. Trying to see if anyone can give recommendations to troubleshoot. I took the plugs out of the skimmer and jets and screwed in the jets contraptions. The water flow to the slide is extremely strong so I don't think it's a pressure issue. I checked both values and they are on open position. I believe the slide is on the same line as the jets so not sure why that would be getting water flow but none of the jets.
Any recommendations or insight would be greatly appreciated.
  • Filter 3.pdf
