I was told that running water features will lower the water temperature of the pool because the moving water causes more evaporation which naturally cools the water. I was wondering if this is actually true and how much it would affect the temps. I have an insane amount of plumbing(20 deck jets, 2 sheer descents, 5 fountain jets, and 2 bullfrog jetpaks) run directly under scalding hot concrete and when I turn on the water features, it dumps all that hot water into the pool. So I'm wondering if maybe I could actually heat the pool by setting a schedule for the water features to turn on for only 1 minute every 20 or 30 minutes just to clear the hot water out of the lines and maybe after a few days it might make a degree or two of difference. I might try it and compare the temps with my neighbor's pool of similar size.
Right now for regular circulation I am running the 5 fountains in the top step and a slight overflow from the spa.
