My system has a water feature pump with its own suction, feeding diverter valve to two falls, or two vertical jets in the splash pad area. Lately the system will not prime. I've checked and lubed the filter basket lid seal, but no change. If I shove a hose in the suction line, I can back fill and if I pull it and close it and start the pump quickly it will prime. But if I them turn it off, it will lose prime in less than 5 minutes. Do I need to install a check valve? Other suggestions? Why are the check valves 2 in to 2 1/2 in?
