When I use my pentair valve activators (Easytouch), with the pump off, as the valves turn I lose water into the pool. My spa and filter are both above pool level. I oversized the plumbing with 3" piping from spa to valve and 2 1/2" for the rest so there is lots of water flow if a valve is open. The activators turn slow enough that I lose enough water to have to pump it back in every week or sooner. What's the solution. If I make a loop and bring my line from my spa higher than the top of the filter (it's higher than the spa) will that do it? or does it just need to be higher than the spa?
I have check valves coming out of my filter and heater so if water is drying from the filter I think it would only drain back into the pump.
Does the intelliflo pump allow water to flow backwards through it when off? If it doesn't, then I don't have to worry about the filter draining. If it does then a check valve from the pump to the filter would stop that, but it wouldn't be necessary with a loop taller than the filter, right?
Jim
Jim
