A couple of weeks ago I noticed water was starting to pool at the corner of the concrete pad where the pool equipment is. I can't see anything leaking on the pad and it appears as though the water is coming from under the pad which if true will really stink. How do I find out where the water (leak) is coming from? I turned the pump off and sure enough, shortly afterwards the water disappeared. Turn it on and it starts pooling again. Who can help this sort of thing (plumber, pool person, ?) I shutter at hiring a pool person because I had one out just to give me an estimate on replacing both the pool light and the spa light and they wanted around $3500. (Was thinking it was a $100 fix). Anyhoo, I need to get this leak fixed but want to do a little investigation on my own.
I also noticed that when the pump turns off, the water in the spa will slowly drain into the pool. I did a little research on that and it seems to suggest replacing the "check valve". Does that seem like a good place to start?
Thanks much for any help!
